the dizzy gasket is just a flat paper cardboard type of gasket. just get one. it is not constantly soaked in oil but it does keep the pcv system sealed.
Good info Thanks
have a good battery. remove your dizzy and and a valve cover. manually prime the engine with a priming tool and drill once you see oil coming off the rockers change the oil and filter with 5w-30 and a low micron rating filter. prime again and once flowing manually turn engine a few complete turns to get all the oil thru all the bearing clearances. once all wet again line up engine for dizzy install. button everything up and prime your fuel charge. you should be able to get this with two key on cycles. on the second one start it and let it do its thing till it gets hot. double check fluid levels. if all is good burn off the old gas as quickly as possible.
while you can put some oil in the cylinder it should be done with a spray nozzle to ensure coverage over everything. do not over-saturate them. it will burn off at start-up.
anything that goes wrong after that likely would have happened regardless and could have been worse. good luck.
---------- Post added at 07:31 PM ---------- Previous post was at 07:31 PM ----------
also expect to need your dizzy fine tuned.
i guess it all depends really... we just picked up a chrysler big block inline flat head six that was sitting on a stand for 18 years (they last used it for some farm equipment) all we did was drain the oil and put fresh stuff in with new filter, swapped the electrical components that we knew worked over and attach it to the tractor and cranked it over... and it runs like a champ after blowing some crud out of the exhaust... if the engine didnt work we'd make up our losses in scrap metal
i guess its up to you... do you know the engine runs? the condition of every moving part? new oil and as long as the electrical components work, fire it up?
my 86 K5 needed a motor so i picked up a 70s 350 that had been sitting 2-3 years... new oil was put in, never primed, and fired her up and she got me around for quite a while... my dad took his perfectly good 68 350, replaced all the gaskets because she was leaking, got some brake cleaner next to a ring, and ended up dry starting her... now he needs an overhaul... its really all luck of the draw when starting an old motor
What about prepping the motor and giving it a few turns manually?
