Hello , I have a 99 Yukon with 5.7. The engine locked up so I decide to do a swap. I purchased a low mileage motor from a salvage yard. The new engine came out of a 96-97 Chevy truck. After I changed motors, it started up and would idle just fine, but when you would give it gas it would start missing. I did notice a few differences in the two. The exhaust manifolds and intake manifolds were different. A friend suggested swaping everything back to original. I changed intake but exhaust manifolds are different (bolt holes are not exactly the same) . I believe the only thing different, other than size, would be the smog pump hoses I Believe. My question is would the smog pump not being hooked up cause the engine to not run. I am out of ideas and don't know what to do. All suggestions would be greatly appreciated. Thanks
