erratic gas gauge
95escahoe
I have a 95 Tahoe and have always had an erratic gas guage for aslong as I've had it (had it since last july) it bounces all of the place, sometimes it stays still most of the time it doesn't, if im on level ground and put the key in the on postion it goes to the correct reading but once it starts up it acts up, in the last month or so the fuel pump went, so new pump and sending unit, and I don't have the bill near by but I think the sending unit for the guage was done too, and the guy at the shop said either the guage wiring is bad or the guage is shot, any other things it could be? and to replace the guage you gotta replace the whole cluster? cause if thats what u gotta do ill prolly just leave it....thanks for the help
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:wtf: Why are gas gauges sunddenly screwing up for people here?
Seriously, perhaps this might apply to you and several others:
File In Section: 8 - Chassis/Body Electrical
Bulletin No.: 76-83-05
Date: September, 1997
Subject:
Excessive Fuel Gauge Fluctuation
(Install Fuel Level Damper Kit)
Models:
1995-97 Chevrolet and GMC C/K 4 Door Utility Models Condition
Some owners may comment about excessive fuel gauge needle fluctuation when making turns or braking with less than a half tank of fuel.
Correction
Install fuel level damper module kit P/N 12167652 following the procedure described on the instruction sheets included with the kit.
Parts Information
P/N Description Qty
12167652 Module Kit, Fuel Level Damper 1
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Op Description Labor Time
N4844 Module, Anti-slosh - Install 0.8 hr
Important : Labor operation is coded to base vehicle coverage in the warranty system.
95escahoe
95escahoe
Subject:
Models:
Correction
Parts Information
P/N Description Qty
lol mines been like this for awhile just gotten sick of it, thanks for the info
crows feet
Elberton Georgia
where can i get info like this,was there ever a recall on the stock exhaust manafolds????got right side replaced under warrenty but other side is cracked also,heard many cracked those years 95 yukon2dr 4x4 5.7.tbi.
992dr
Eastern N.C.
It seems to be a pretty common problem this "hummingbird effect".
I believe your problem is with the stepper motor in the gauge that is going bad.
This has been going on with mine forever. One day I'll replace it, I have a list of other things that need to be replaced, this is not very high on my list, hah.
95escahoe
95escahoe
is the guage its self replaceable or do u gotta do the whole cluster?
SunlitComet
OBS Jedi-Do Good
No tsb or reecalls on 9'95 exhuast manifolds.
There are replacemnts parts but you might have to talk to a instrument cluster specialist to get one. I can't seem to find and part number for it.
992dr
Eastern N.C.
Hmm, not quite sure. I'll have to get back to you on that.
I had started a thread on another forum a while back about this. I'll go pop on over and ask the same question.
I have heard the parts are hard to come by but, just not sure what exactly is to be replaced.
EDIT : Only the stepper motor needs to be replaced but if you dont want to dig into the cluster then just replace the whole cluster
95escahoe
95escahoe
thanks for the help guys. na dont really want to mess around with the cluster ill just live with it and keep track of how many miles driven since filling up
Jsuthe
