Escalade Interior
Modded
That Guy
Either I'm drunk or tired because I am confused too.
soulsea
soulsea
Bar
lol, you don't have to get them escalade doors if I get you the piano black b pillar stick ons and the chrome sill stick ons.
Oh what a father's day it will be!
felixgun
Lafayette, LA
Modded, the 2012 premium escalades come with a center console shaped just like all the Tahoe/Yukon's that are 07+ (with the little insert in the middle) so i'm betting it will interchange. The platinum escalade has always had the center console like the 07+ tahoe/yukon's except it was a blushed aluminum (instead of just un-painted black plastic) trim whereas the '12 premium has matching woodgrain similar to the rest of the interior. It is a direct swap and a mod I def want to do one day.
Serge, I think it's a great idea. If the colors are identical then you should def do it! I think the cashmere in the esky's are a lot lighter in color though...
---------- Post added at 11:29 PM ---------- Previous post was at 11:26 PM ----------
I think it's ugly because it doesn't flow like the Denali. The Denali interior has a nice flow with the two tone.
Secondly, but swapping out the upper panels, it will require new interior door handles since the Denali and Escalade do not share the same handles. Now, due to the fact that the Denali handles have the heated seat controls integrated into them and the escalade ones do not, he would have to relocate the heated seat controls elsewhere inside the vehicle. This also would create a problem with the electric wire harness inside the door since the Denali one has the wiring for the seat controls in it and the Escalade one does not.
The other issue is that the upper leather piece is not a separate part number. You would need the entire door panel unless you find a salvaged piece.
Only option would be to have an upholsterer match the leather and do the insert. I personally like the darker leather on the top as its were most folks rest their sweaty arms on the door when you are driving.
What is different about the interior handles between the esky and denali? I didn't realize they were different...
cam71374
