Esky third brake light not working
04silverL
Pleasant Hill, CA
Need some help. Hooked up my esky third brake light via the how-to and for some reason the light des not work when brakes are applied. I hooked my stock light back up and it worked fine. Any ideas?
ChevyFreak
New York
I am sure someone else can offer up an opinion, but if I had to take a guess, I would say that maybe the esky brake light itself is out. Whether it is damaged, or simply a bad bulb(s), I don't know, but that would be my initial thought based on your original post. Also, I would check your connections again. Possibly, something came undone, or was not quite hooked up right when you had the esky brake light plugged in.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
check and make sure the pin is aligned in the connector. I had that problem. You can also add power to the pins. Black is Ground and color wire is power. After added power, it will light up. If all else fails, i have a extra esky Light bar in red.
04silverL
Pleasant Hill, CA
Still have not resolved this issue. This was bout on here and am extremely unhappy with it not working when I received it, so I wasted $300.
drroy
have you tested it off the truck: applied 12V to the prongs to see if it works? If you test it and it doesn't light you have your answer, a non functioning light. And you would need to cut it open to repair.....so yea you may have wasted $300
soulsea
Administrator
Bar
04silverL
Pleasant Hill, CA
Yeah Im gonna test it this weekend. Asked for a refund and nothing. If I test it and it does not work then I will make a post explaining everything
bluer
