Exhaust Manifold Bolts No Bueno
Derick
Indy Suburbs
I have the dorman clamp for right/front, left/rear if you are in need. 30 bucks shipped....brand new.
donjetman
donjetman
Yeah a few bolts popped off on the suburban. I took it in for some exhaust service anyhow, so they took care of all the broken bolts too. From what I saw, GM used M10 heads, and they all broke. Replacement bolts are M12 and are far better.
Exhaust manifold bolts are gonna be another project for another time. I'm gonna let the sleeping dog lie for now.
Other future project are: new Arnott rear shocks, 2 door handles are acting up. I have a spare Topdog engine oil bypass filtration setup off a vehicle I sold that I can put on the Yukon. I'll utilize an ICT Billet OIl Cooler Adapter
https://www.amazon.com/gp/product/B072MKMWFM/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
to come and go from the engine.
Derick
Indy Suburbs
Well these products are literally exactly for that attitude. They use two existing threads in the block, and use a third bolt to push down on the manifold to make a better 'seal' for the manifold. Someone mentioned it earlier, didnt go into depth on what they do, but it's a bandaid to get by and cut down the exhaust noise. I had the opposite unit that I wish the exhaust shop would have given back to me.....but oh well.
Scottydoggs
NJ
ive done this repair. removing the manifolds not all that bad. looks like the heads popped off, better then flush to the head. once the manifold is off vise grips get the old bolt out easy.
i re used the factory gasket, and got manifold stud and nut kit.
Ilikemtb999
Denver
Time to get headers!
With that many broken I’d just do it the correct way vs the dorman fix. If I had just one, I’d go dorman.
donjetman
donjetman
I would love to install stainless headers, but too many projects, not enough time. I have the Dorman fix coming in the meantime.
FYI the driver rear is almost impossible to get the Dorman clamp on due to the firewall. Some guys have figured a way but it ain’t easy. The others are a breeze.
I was about to say that Don's a jet man, which had me thinking he is/was a jet engine mechanic and probably has tools that turn bolts around blind corners.
On that note, Don, what's your affiliation with jets- Air Force? Pilot? Mechanic?
Maybe you and Mark (@Rocket Man) can share your propulsion stories.
donjetman
donjetman
I was about to say that Don's a jet man, thinking he is/was a jet engine mechanic and probably has tools that turn bolts around blind corners.
Retired civilian pilot, 7 jet type ratings, smallest was the Citation Jet, largest B-737. I wanted to be a mechanic. My family doctor knew I had a bad lower back. He said don't plan on being bent over a fender all day for a living. I took his advise, until I retired :) I don't get near airports anymore. Been there, done that.
Tools? Harbor Freight, nothing but the best for me ;)
My back's killing me from all the work I've been doing on the Yuk.
a2015gmcyukonxlde
