Exhaust Manifold Gaskets/Lifter Tick
JPVortex
JPVortex
Connecticut
By the way, don't think i've posted any real pictures of the truck that this is happening to. It's a black Suburban Regency Edition. She's definitely a decent looking rig, with rotted rear rocker panels. Frame is as solid as can be. I have to say, since September when I bought it, it has become pretty special to me. I don't know why, but it just has.
rockola1971
Indiana (formerly IL)
There are so many avenues to take on this. If you cant afford another vehicle and have to have this one rolling, either grab a used engine if you can find a Gen3 with atleast below 200k or take a chance on the engine you have and pull the heads and see whats going on. It really all boils down to how much money you have to pay for the avenue that works for you. There really is no way around not having some inconvenience while your only vehicle is down, but it will really be inconvenient with a completely locked up engine scenario that you havent planned for. I recommend a girlfriend with wheels, we will call her Suga Momma.
As far as quarter panel rot, who cares. The vehicle gets you from point A to point B when you need it to. It aint no show car and never will be. It doesnt have to sparkle or shine. This generation C/K chassis is extremely dependable and typically stupid easy to work on when needed. It will last you many years with relatively low maintenance costs if you can do them yourself or have friends in the know. The LS engine platform is well known to go 300k+ with just regular oil changes and basic maintenance of plugs, wires and sometimes ignition coils. Not alot to go wrong.
JPVortex
JPVortex
Connecticut
I agree! I don't think the rocker rust is a reason not to swap the engine out. Can't afford another vehicle at this point, but probably will pick up a cheap beater to drive while the suburban is down.
Quick question, doing research. I plan on pulling the engine by itself, leaving the trans and tcase behind.
When lining up the engine to go back into the truck, do I need to align the engine with the engine mounts AND the bell housing at the same time? Or will there be room to first get the engine set where it's supposed to be on the engine mounts and then get the bell housing lined up later? Sounds like it'd be a pain to have to get the bell housing lined up first before the engine would line up with the mounts. Honestly, that's the part I'm most worried about with the whole thing. Rest of it is just disconnecting stuff and reattaching really.
Scottydoggs
NJ
you'll need to lift the engine up after pulling the motor mount bolts, then put a jack under the tranny to hold it up once the engine is pulled from it.
then mate the engine back to the tranny then lower them both back down.
JPVortex
JPVortex
Connecticut
Sounds like sort of a pain lol. Think it’d be easier to just pull the engine and trans together?
so sounds like when reinstalling, the engine and trans do need to be mated before dropping the engine completely back into the mounts?
Scottydoggs
NJ
if the trucks a 4x4, just pull the engine. the engine only needs to be lifted above the mounts, like a couple inches. pull the bell housing and tc bolts before lifting it, then once lifted split them apart with a jack set under the trans to hold it in place, or its gonna hit the floor and break stuff. if using a leveler bar to lift the engine out with, they come in handy for when reinstalling for sure, as you can easily change the pitch of the engine to mate to the tranny, once mated pop a couple bell housing bolts in place to keep it tight. pull the jack and lower back to the engine mounts.
JPVortex
JPVortex
Connecticut
Thank you, this paragraph totally cleared that up for me. Will definitely be using a leveler to get the tilt I need out of it. Probably going to get a leveler with 4 chains coming off of it, so I can support from 4 different angles. Seems to be perfect unused bolt holes on front and back of each head that I can put grade 8 bolts into.
Scottydoggs
NJ
thats how they work, 4 pt chains, harbor freight sells one. used to be like 30 bucks. not sure what they go for now tho. i got mine like 8 years ago.
mikeneedshelp
