Exhaust Manifold Gaskets/Lifter Tick
JPVortex
JPVortex
Connecticut
thats how they work, 4 pt chains, harbor freight sells one. used to be like 30 bucks. not sure what they go for now tho. i got mine like 8 years ago.
it's like $45 now, not terrible. Definitely going to be the easiest way to get the trans and engine remated though. I appreciate your help big time.
Scottydoggs
NJ
only issue you might find is if your hoist will go high enough to clear the oil pan past the rad support. might have to choke it down real tight.
JPVortex
JPVortex
Connecticut
Can always pull the rad support off if needed. I also don't want to get one of the cheap chinese harbor freight hoists. Kind of thinking of getting something more heavy duty that's used on Marketplace. They definitely seem bigger than the harbor freight ones.
Scottydoggs
NJ
the hf one ton is pretty good. i got the smaller one cause i was pulling car engines. and that boom ended up being to short, had to drill a new hole and pull the beam out further.
gknowels
