t_ahan
need some input and advice to start addressing the much needed fuel system upgrades...
so i am looking to get new injectors and a fuel pump (if necessary since mine my oe still has not burned out)
When i did my build i knew injectors would be needed but with my light/break-in feeler tune i was 75% duty cycle. Earlier this summer i finally got a BB Tune in person by Justin and he also confirmed i needed to do something about the injectors to get the full potential out of the set up. Once he was done tweaking we were at i think 95% duty cycle(maybe 99%,i 4get) either way i am maxed out on fuel delivery and maybe supply.
options so far:
47# part# M-9593-G302 (ford injectors???)
46# part# 30462-8 (FAST)\
44# part# 32D-00-0044-8 (deatsch werks)
30# part# DFP-FJ10494 (stock delphi chevy 8.1L injectors)
of course the re-tune, then i need to figure out what fuel pump to use!
b4 i contact BB i thought i would get some input since i am undecided
any advice/opinions/experience would be greatly appreciated!
thanks every1
Build Set Up:
'03 LQ4 .030" over bore with Wiseco forged pistons, stock length eagle forged I beam rods, melling hv oil pump, cloyes billet timing chain 3bolt, arp rod bolts, arp main and head studs, 0.000 deck gm 243 heads , comp valve springs, comp cam-xfi rpm cam [email protected] intk216 exh220, comp lifters, comp hitec push rods7.4"length, comp ultra gold arc series 1.72 ratio rockers, fast lsxrt 102mm intake manifold, fast fuel rails, aeromotive fuel pressure regulator, bbk80mm tb, k&n cai, bbk shorty headers, magnaflow cats and back, and preformabuilt level2/heavy hauler transmission with a 2500stall tq conv, BB Tune
options so far:
thanks every1
Build Set Up:
