I would think that Alldata would have that. Found this, though (#3 on diagram):
Thanks! I ended up testing and found out there's no electrical issues in my fuel pump circuit. I maybe dense... I cannot figure out a great way to search AllData (at least the old version). I search for connector numbers and nothing comes up. Then I went to connectors by number and it didn't list C152. Thanks for finding that!I would think that Alldata would have that. Found this, though (#3 on diagram):
I believe these are inside the fuse box. Pop the the little tab and the fuse panel swings up/out.There is a connector, C152A (also C152? connector on wiring diagram but not listed in FSM)... I cannot locate it? Anybody know where it is?
Interesting. Yeah, definitely should not be dropping pressure that much. To determine if it's an injector or the checkball, temporarily plug the return fuel line at the rail. I did this once with a vacuum cap and hose clamp. Prime the system and the pump will deliver maximum pressure (80 psi on mine IIRC). If an injector is leaking, it will drop pressure. If pressure doesn't drop, then you know it's not injectors and most likely the pump checkball.I have a return style setup. My Key On Ignition off pressure is 48PSI. 7 below spec which is 55 to 62 PSI.
I noticed, fiddling with my Corvette that the gauge will PEAK in the 55 to 62 PSI and settle down a bit lower, possibly even touch below that range. I'd venture you're pump is in great shape if you get 54 PSI during that test. Mine falls to 40PSI when engine is rev'd.
I have a new pump from Delphi (warranty replacement). Original pump I'm quite sure was bad regardless of pressure because the line set bled off quickly after engine & pump were shut off. It'd bleed down to like 35 PSI in a matter of minutes. This new one hold pressure in the lines even as much at 15 minutes later non has bled down.
Delphi tech support has me checking circuitry. They said to do voltage drop tests. I'm going to do that now. One across the whole line for starters then break into the positive side then negative side if necessary. Current draw, patching my amp meter in in place of relay was 5AMPS. I think maybe supposed to be 6 AMPS but battery charge was low. Lots of stuff I'm checking... Will update here as I go through whole process. I should have tested the voltage drops when I had the tank dropped. Now I have to drop it again *sigh* all be it only part of the way to access top of pump.
Or just pop the fuel rails, prime the system and let it sit for a bit. If one is leaking down, it will be pretty obvious. Put some shop towels down in case there's fuel coming out of them.Good idea
So I did what you said. I found a way to disconnect and cap the return line. I put on a test gauge.Or just pop the fuel rails, prime the system and let it sit for a bit. If one is leaking down, it will be pretty obvious. Put some shop towels down in case there's fuel coming out of them.
