factory console amp and bose sub inop
zomeizter
zomeizter
North AL
That may be overkill though, can't seem to find any lower wattage ones easily (gonna chec wallyworld), I have a couple bridgeable amps in the garage, will prolly try them and see how it goes, like i said before, smooth lows for now is all I want, will eventually install the big woofers out back to "feel" the bass :)
qukon 95
400 RMS @ 1 ohm should be safe remember the amps have gain controls you can adjust down if needed
A 2 ohm stable amp will only heat up and shut down especially if it's a A/B class amp class D amps
Are cheaper also. I did get my mtx amps at crutch field $135.00.
zomeizter
zomeizter
North AL
ok kewl, guess I will be fabbing a box for the space where the changer and rear audio controller were installed now that it is all apart. Thanks for the info man, will be ordering the amp next.
jgrundy13
