Fast stop requires turinging off than on in the Denali
jcevans7
Friendswood, TX
I have a 03 Denali bout 134k on it. I did a brake fluid line flush because I had a issue with braking. Seemed to only happen if I slammed on the brakes or made a stop that would bring the pedal to the floor. The truck stops fine but after that it's like the breaks still lock. I have to slam on the gas and I'll creep away. After the fluid line flush it still did it this time on the interstate. Nearly got smoked. Slammed on the gas to get out out the way started burning up pads had some smoke.
I turned off the truck throw it in park wait a couple minutes take off no problem. Just had it happen again at the local store, seems like when it does I have to throw it in park and turn it off than on to reset it.
I checked the pads they have plenty left on them, rotors are smooth plenty of life left. Breaking at normal speeds the Denali is fine. Not sure where to go from here.
redemn93
Jupiter, Fl
sounds like sticking calipers. happened to my bosses 05 silverado. or ABS unit being funky?
jcevans7
jcevans7
Friendswood, TX
ABS has been fine. Light never comes on truck never does the pulsing when I make a fast stop too.
jcevans7
jcevans7
Friendswood, TX
Thanks I will look it up tomorrow leaving work where it is and try it before I pull in to the drive way.
QUYHMK
