I didn't flame you at all! I'm tryin' to help you, and if you understood the relationship octane has to compression, you would have known that! If you're too sensitive to take advice, don't post up! I can't stand people who flame others, and I love to be able to help when I can, but if you don't want to listen, just say so and I'll keep it to myself! .....but if you care to know:
You can't cheat these things. Octane ratings have nothing to do with "making" horsepower and "magically" improving gas milage. Octane needs to be matched to compression ratio. THAT'S IT! The more precise the match, the more efficeint the burn. The more efficient the burn, the more your engine can realize it's full potential. You're not creating more power, you're just allowing your engine to make the power it's already capable of making. A more efficient burn will also yeild better gas milage, because, well, it's more efficient.
A good rule of thumb is to look at your compression ratio and move the decimal point over 1 digit. That's the octane rating you should be using. That's the best way to achieve the goal you're trying to reach. Too high of an octane rating is not much of a big deal, you just waste a few pennies on gas, but too low (like you're doing) WILL cause detonation and lead to an exploded piston. There is no way around that fact! Do you really want to blow your engine trying to save a few pennies? Because the cost benefit ratio seems a little off balance to me, but that's just my opinion!
