Finally fixed my 6.2 low oil pressure!
2K8Lade
I think I finally fixed it and wanted to post this for others. I had done the pick up tube O ring before with a red O ring from Rockauto. It was good for about 15k before low oil pressure when cold came back.
This time I used the Melling kit with the green o ring. It was much beefier than the previous replacement that was pretty defeated looking already. I also made sure to clean up the pickup tube where the o ring sits.
I also pulled the useless oil pressure relief valve and pulled it with a kit from Summit. My Escalade is a 2008 so no AFM.
Hope this helps someone!
Geotrash
Dave
Richmond, VA
Thanks for following up. I had this exact same experience with my 2012, which is why I had to drop the pan a second time to replace the o-ring. I also replaced the pump at that time with a Melling unit that had the green thicker o-ring. No more problems.
2K8Lade
I hope there's no more oil pressure problems. Getting to it with AWD is a job!
donjetman
I had good oil pressure but replaced my o-ring for preventative mx 4+ yrs and 45k miles ago. I used Felpro# 72401. No issues (yet). If I ever drop the pan again for something, I'll certainly replace the o-ring just because they're only new once.
BigD253
