FLEXPLATE ISSUES…
Walkercraig01
how much was the new flex..yea ive put new starters on have two new ones now lol. shims everything.. only thing i havent done is replaced the bolts on the starter one seems a little bent
Eman85
A few bolts and the inspection cover is off and you can see the flywheel, easy to see if it's bad. If you have a bent starter bolt there is human error involved, they don't just bend from use. Either wrong bolts installed, very common by humans, or starter not installed properly.
the 18th letter
Northern New Jersey
I don’t recall at the moment how much the flex cost but I know I got the paperwork someplace. The guy who ultimately fixed it explained my flex was eating the starters because of bad teeth. He fixed it in probobly 2006-7 and been reliable since. Get a new bolt as well, that can’t be helping the issue.
Definitely not a cheap issue to repair since the transmission needs to be dropped to replace the flex plate. Had to do it for both of my Express vans, and my Tahoe.
Joe03z71hoe
