Fosscore's 2006 Tahoe Build Thread
DDenali
Orangeburg, SC
Woke up way too early before sunrise today, so I decided to get up and wash both the Suburban and Tahoe in the peace and quiet of the dark morning. Can't complain about the weather as it was 64F and clear this morning. Sorry for you guys in subzero temperatures right now. I gave the engine compartment a good rinse and will dress it up later. I also clay barred her from the roof to the rocker panels as she will be getting polished out later this afternoon and evening in preparation for the HD hood getting put back on.
Here are some pics from the shop. Very excited to get her back on the road.
I'm drooling my day will come
Sent from Dugar's iPhone 7 Plus using Tapatalk
Fosscore
Fosscore
My HD hood and Esky vents should be done at the painters this week. I decided to give the rest of the paint a detail since she has been off the road for the last month. It turned into a bigger project than I anticipated once I started polishing away.
The roof was pretty bad as you can see from the test patch. Nobody likes doing that much real estate with those fins and it is a pain to reach, even with a step ladder. I ended up pulling the Esky roof rack to make sure and get the entire roof. While I had everything out, I went ahead and polished out the windows to get rid of the water spots as well. What a world of difference that makes. I also dressed the engine compartment with some 303.
This is the process I followed:
1. Wash.
2. Clay bar.
3. Wash.
4. 3M™ Perfect-It™ Rubbing Compound (PN 06085/06086) for the roof due to the oxidation.
5. Meguiar's Ultimate Compound Automotive Finish Restorer.
6. Meguiar's Ultimate Polish.
7. Surf City Garage Shine Nano Glaze.
8. Surf City Garage Nano Sealer.
Working on the roof.
Using AquaTech Water Spot Remover on the windows.
I used it with the DA and in the tiny spots, used my fingers and a microfiber. Finished with Rain X.
First test patch on the roof at night, which sent this project into overdrive the next day.
Small square test patch and a bigger square close to the passenger door. Really shows you how bad your roof actually is if you haven't given it a proper detail. Looks shiny, but hides the oxidation, especially at night under a bright LED light.
fresh350
I'm about due for this after all this snow... looking damn good!
BADRIDES
Where did you get the Aquatech water spot remover from?
Slammedchevy01
Looks beautiful , wfats easiest way to pull esky rack or well end caps? I've had mine on for a few years but always worried about cracking the endcaps!
05Single
afraid of the dark
I use steel wool and glass cleaner for anything on the windows.
That's the problem in Florida is that hard, almost like an acid rain. Destroys paint unless your keep up on maintenance.
As always truck lookin perfect. Have you thought about a 6.0 engine cover?
Blitzfury
