FREE TRAVEL MOD HELP
Dimond9035
Dimond9035
I used a saw zaw with a heavy duty metal blade it was flat on the end not like the traditional pointed tip so if it hits the gas tank it doesn't puncture it and you just pull back a fraction,
Dimond9035
Dimond9035
I used a sawzaw with a 9 inch blade I used some heavy duty blades that are flat at the end instead of the traditional pointed end, this was helpful for when I hit the gas tank it did not puncture it instead it gave me a warner to pull it out a little bit
nharkey85
Alabama
Saw all here as well. Wanted to go with die grinder/cut-off wheel setup but my compressor won't keep up with high speed rotary
Sent from my SAMSUNG-SM-G920A using Tapatalk
vestjam
