Derick
Hmm two year warranty....This one from RA is $753.79 plus $400 core charge
https://www.rockauto.com/en/moreinfo.php?pk=8805384&cc=1380372&jsn=1045&jsn=1045
economy choice- junkyard, just look for one that looks like it may have been resealed already I wouldn't worry about the axles those are cheap if one needed to be done later
most junkyards will give you at least a little warranty so if it happens to be bad out of the gate no big deal
new oem ones are $259 at rockauto, $57 for a re-manufactured cardone with lifetime warrantywhere do you source "cheap" axles? How cheap? Do you think they would last 100k miles? Im in, cause oem are mucho denaro $$$$$$
If you can drive something else while the truck is in for repairs, financially it will never make sense to buy another truck. Do the math on the cost of the new vehicle compared to these repairs and you will see. If you like this, then just fix it. Math says never sell a vehicle that suits you needs. Literally anything can be fixed, unless of course it is in a wreck.So, I listed the burb. I cant stop throwing money into a hole in the ground. The damned of it now is that it's running pretty well. No exhaust noise, motor seems smooth as silk, trans is fine. The body is right at the edge of erupting, which is sad...
Last year I did a oil change of the front diff, and it was a metal slurry in there.
I change it again last weekend when I did the hub/bearing installed...and it's more metal.
I have no noise or problematic symptons....yet. So what should I plan to do with the diff? Should i source one from a junkyard, are there rebuild kits? Obviously, thriftiness is core here.
