front end needs work... ideas, tips, suggestions?
W
wintergreen
My rig is a 98 2door 4wd with 240K miles. Here's what I recently changed.
Ball joints - upper and lower, both sides
Inner and outer tie rods - both sides
Center Link - just cause everything else was being changed
Pitman Arm
Idler Arm
Idler Arm bracket
I bought all Moog parts from Rock Auto. I forget exactly but all that will run you 350 to 450 in parts. Rock Auto and Amazon have great prices on quality parts.
I looked up all that plus my catalytic converter and shocks on rock auto. That IS a shopping list for sure...
Are there any other preferred brands besides MOOG? Is ACDelco = GM? Can I mix and match brands? Are there fit up issues? Also noticed there was no option for lower control arm. They had upper 4WD (even some with ball joints already done) but no lower, whats with that?
I just got my factory service manuals in the mail.
Here's what I've got:
1999 GMC YUKON 5.7L V8
Suspension : Ball Joint
MOOG Part # K6477 Problem Solver
Front Lower; Incl. powdered-metal gusher bearing to allow grease to ********* bearing surfaces; Press fit ball joint; w/stamped steel control arm; w/45.79mm Press Fit Type Ball Joint; 4WD B
$30.79 $61.58
MOOG Part # K6292 {#K6370} Problem Solver
Front Upper; Incl. powdered-metal gusher bearing to allow grease to ********* bearing surfaces B
$23.79 $47.58
Drivetrain : CV Half Shaft Assembly
EMPI Part # 801503
Front Left
Front Right A
$69.79 $69.79
Steering : Idler Arm
MOOG Part # K6447 Problem Solver
Front; Tapered stud increases stud to bearing contact area by 35 pct.; w/o frame bracket B
$46.79 $46.79
Steering : Tie Rod End
RAYBESTOS Part # 4011428 Professional Grade
Inner; 4WD C
$36.79 $36.79
RAYBESTOS Part # 4011422 Professional Grade
Outer C
$35.79 $35.79
Steering : Idler Arm Bracket Assembly
MOOG Part # K6722 {#K6532} Problem Solver
Front; Incl. powdered-metal gusher bearing to allow grease to ********* bearing surfaces. Incl. bracket assy. and problem solving grease hose kit.; 4WD B
$52.79 $52.79
Steering : Center Link
MOOG Part # DS1407
Front; Non-Wear Item; 4WD B
$33.89 $33.89
Suspension : Shock Absorber
MONROE Part # 911043 Reflex Light Truck
Front; 4WD B
$35.89 $71.78
Steering : Pitman Arm
ACDELCO Part # 45C0045 {#88911230}
ARM,PIT -
ARM,PIT -; 4 WHEEL DRIVE C
$36.89 $36.89
Suspension : Control Arm Bushing
MOOG Part # K6329 Package Quantity As Shown In Image Incl. front and rear bushings
Front Lower; w/Steel Stamped Control Arm; 4WD B
$17.82 $17.82
MOOG Part # K6395 Package Quantity As Shown In Image Incl. front and rear bushings
Front Upper; Standard Design; Incl. front and rear bushings B
$13.92 $13.92
Subtotal $525.41
Total $525.41
...It's alot of money. Just want to make sure im doing this right. Thank you.
97Tahoe2d4x
SF Bay Area
That's an impressive shopping list and you won't have anything to worry about front end when you're done.
Since you are taking it all the way, don't forget new sway bar bushings and end links...just a thought.
Energy Suspension poly sway bar bushing/end link set is like $35.00 IIRC, give or take a few
depending on where you get it.
Good luck with your project.
saif najd
I have the 98 tahoe 2dr and I started this bath,
I did replaced the front upper joint balls (GM) and the upper pushing for the upper arm and still I have something lose!
saif najd
Steering ends needed replaaceing also (moog)
McFizzl
Broke as a Joke.
Fayetteville, AR
I will have to do all this soon. within the next year maybe. You can watch the front end of the truck shake side to side while still going in a straight line. My steering has a lot of play and all the steering components are loose and worn out.
saif najd
:banghead: :banghead: :banghead: I did everything but still the noise of something loose is there :mad:
foreverfalcon40
First you do not need to rent a lift to do all the work, save the money and spend it else where.
You can rent a BJ press kit and axel socket kit from your local parts store like Advance Auto. Advance also sells universal poly stabilizer links, grab those dirt cheap and you can install them with out even jacking up the truck.
For help check YouTube.com. I have not looked but guarantee there are some videos to do so. Do you have any tools?
YukonCountOnMe
If your stock ball joints have never been replaced the uppers may be riveted in. If so I would definitely suggest buying the whole upper a arm with new bushings and all from rock auto. The new bushings will help the ride and the a arm comes with a bolted on ballpoint I believe. It's a straight ***** to get the rivets out. I wish I would've just got the whole a arm
CoyotesRUS
