Front Passenger Seat Stuck.
The OP hasn't been on here for over 3 years, so I doubt you'll get a response. Suggest you use the search function, as this situation is regularly discussed.
The tilt on my passenger side seat is stuck, the seat moved forward and back and the seat warmers work, any suggestions???
Might be the switch, or the motor or might be mechanical. What does it do when you hit the switch? Any click to indicate the switch is doing anything? I believe the driver switch will plug into that side so you can check if that’s the problem. Otherwise you’ll need to remove the seat and inspect the motor and screw mechanism.
Big Mama
Virginia
Can you hear anything when trying to tilt it? Take a look underneath while testing it.
Djohnson99
