clandr1
yeah there are no inner and outer bearings just a wheel hub. 35 or 36mm nut on there i for got which
I believe you only need the 35mm nut if you have a 4WD. 2WD should only require a normal size socket for the three or four bolts holding it to the steering knuckle.
