Front Sway Bar Links
dbbd1
Silly question?
When you all lower your SUV's, what are you doing about the front sway bar links? I know that someone of you have replaced the rear links but what does your front sway bar angle look like?
Kpwweb
It’s really not that bad: Mine has been lowered between 1-2” at different times in the front and the front links were not a problem. Maybe 3” or over, but not with 2” drop or under.
The rear was a problem because the ends of the bar hung down and was beyond parallel with the ground. The front is not a 1:1 ratio like the rear since the bar does not attach at the end of the a-arm but in the middle. So there is less movement of the bar with more movement of the wheel/suspension.
dda1
