strutaeng's 04 2500 4x4 project Suburban
strutaeng
strutaeng
Dallas, Texas
Well Saturday my oldest daughter had a championship M.S. varsity volleyball game. Unfortunately, they lost. Got home and they had 50% chance of rain, so all I did was wash and held off masking. I did an engine oil change instead. The drain bolt was super clean. Of course, it didn't rain on Saturday after all, LoL. But Sunday we got a downpour.
Tonight I dropped the transmission oil pan. I started loosening the bolts and ATF started dripping everywhere. This pan doesn't have a drain bolt. I grabbed a drill and drilled a small hole where the drain bolt would go (I have another drain pan with the drain bolt laying around to swap.) Kinda of a pain actually to remove though. I realized towards the end the crossmember has these holes to slide a 1/4" ratchet and put a socket at the other end to remove the rearmost bolts.
strutaeng
strutaeng
Dallas, Texas
Got the other transmission pan reinstalled. I couldn't get the rearmost pan bolt: tried and tried and finally gave up. I removed the crossmember.
I drilled some 'ol holes and cut some reliefs on the transmission mount. Hopefully next time I replace the transmission fluid this would be a bit easier.
I just drained the transfer case and this is what came out. It looks and smells like ATF. I believe this transfer case requires some blue-looking fluid. I already dumped it, but that only looked like 1/2 quart. :-(
strutaeng
strutaeng
Dallas, Texas
If it's an NP8 RPO NP246 two-speed case it takes just short of 2 quarts of Auto Trak II (yes, it's blue).
I'll double check the RPO code on the glovebox, but I'm pretty these SUVs were only offered with that transfer case. It has the round pushbutton with "Auto."
There should be a round badge bolted to the case unless it's been removed.
EDIT: I'll bet the TC is ruined if they used tranny fluid in it; might need a rebuild.
strutaeng
strutaeng
Dallas, Texas
Umm. When I bought the truck the owner's son told me it was stuck on 2Lo and that's how they had been driving it.
I checked underneath and wiring harness to the transfer case motor was severed. I respliced everything but still nothing. Then I replaced the little reluctor wheel on the motor (I can't remember what the part is actually called.) That fixed the problem. TC works from 4LO, 4HI, and the Auto function. I confirmed by jacking the rear end on the air and I was able to pull forward.
I just drained the fluid from the pan and didn't find any glitter or clutch material. My understanding is that the NP246 uses some clutches similar to a transmission (actually shares the clutches with some Dodge transmission?) This is my old transmission pan where I drilled a hole, hence the duct tape. LoL
I guess I need to figure out what to do now? For sure I'll be at least replacing the correct TC fluid.
strutaeng
strutaeng
Dallas, Texas
Also, my Dad and brother was here to morning. His OBS truck had his fuel level sender go out so they needed my engine hoist to lift the bed.
Anyways, I had them help me install the hood. The color looks like a pretty good match. The only thing is on one side the hood is bent a bit and I didn't realize it. Oh well, probably happened from it leaning against my shed for several years. I'll order a bug flector and it should be fine. :)
It was super windy today so I didn't even try to paint the roof. And we are supposed to get a cold front later this week. Doh!
Jimmychu
