MickeyD
- Joined
- Nov 2, 2019
- Posts
- 20
- Reaction score
- 7
Hello all,
An issue cropped up on my dad's 2003 Suburban yesterday that I'd like some help with diagnosing. He filled it at a gas station, then after that, the fuel gauge has decided to point every which way. The gauge was pointing around the 5 o'clock position (way past full), then back some, then even further to the 7 o'clock position. Basically, it's not stuck one way, but rather, it decides to point in seemingly random directions.
From the bit of reading I've done, I suspect the culprit is the stepper motor for the gauge in the cluster. I know the sending unit can also cause the gauge to read incorrect or to get stuck, but because of the erratic behavior of the gauge, and the fact that I believe the sending unit was replaced as part of some maintenance a few years back, I don't think this is it.
Oddly enough, it seems that the gauge for the oil pressure is also acting up. It seems to peg at maximum pressure. I know this may be a separate issue (we haven't had to replace the sender or the screen under it yet), but I thought I'd add it. I suppose a grounding issue on the cluster or the fuel level sender could also be the culprit.
What I'm asking is 1) is this a common issue and 2) what is the common mode of failure? It's not a problem for me to replace the stepper motor if that's the issue (I'm an electrical engineer, easy repair). But if it's common for the sender to fail causing this, that's a little less fun to fix.
Thanks for the input!
