Fuel Injector Cleaner?
Denali0229
FL
Does it really work and do you all recommend using it? If so, which brand would you recommended for a 2007 Yukon Denali? I'm a rookie when it comes to car maintenance and/or mechanics. I just always assumed this was a way for the oil companies to suck another $5 out of ya. But I just ordered my BB tune this morning and I figured I would do any maintenance things I can now while I wait for it to arrive.
Denali0229
Denali0229
FL
Sheriff
I was originally looking at the Chevron fuel injector cleaner but didn't feel like driving back to the Autozone this morning so I figured I'd use what was available at the nearby gas station. I ended up getting the STP version. I'll give Chevron a try next time.
I have always heard Chevron was the best. I have 10 injectors in my V-10
Excursion and it does make a noticeable difference every time I use it.
I need all the help I can get on a 8 mpg vehicle. :)
Big Bad Allis
Grand Rapids, MI
The Chevron with Techron isn't bad for a retail purchased pour in the tank product. If you really want to properly clean the fuel injection system you need the proper tools to perform the full service. There's 3 items. Throttle body,and air intake cleaner as well as the more concentrated product that is poured into your fuel tank. You might find a dealer that will sell you the better pour in the tank injector cleaner. Valvoline VPS (Valvoline Professional Service) is good, BG is good. Their most popular is the 44K. MOC Fuel Injector Cleaner and Wynn's.
The professional products have a higher concentration of PBA's and the rest is basically just a delivery agent. The STP and most other retail products are mostly carrier fluid and a little of the actual cleaners PBA.
edgaranah1
Corona California
I remember reading somewhere that GM doesnt recommend using additives to ones engine and i was skeptical to use it but I used it anyways when I had a knocking sound coming from the engine. after about two to three weeks that 'knocking' sound dissapeared and havent hear it since. so now i give it a thumbs up
gnarpow
Denver, CO
This is interesting. Mine has about 95k miles on it + its a GM = knocks every cold start.
What additives did you use that seemed to make it better? I'm willing to give this a try
edgaranah1
Corona California
i never heard a knock on my 07 yukon before and it has it has 82k on the clock. I used the chevron one, dont really know the name. a friend of mine have me the bottle he says he uses it alot. didnt really heard or felt any difference for about two weeks after that the knocking sound that had developed dissapeared hopefully it wont come back.
HOE-N-IT
Virginia
The owners manual for my 2011 recommends using the GM fuel system cleaner at every oil change interval if you do not use top tier fuel. I did a search some time ago and found out the GM Cleaner is the Chevron Techron. I bought the Techron at Walmart. They only had the small bottles that treat about 12 Gal (can't remember exactly) so I put 2 bottles in and filled up. Was about half the cost of the GM branded cleaner.
jason05
