Fuel Injector Cleaner?
Big Bad Allis
Grand Rapids, MI
What do you think about seafoam?
Seafoam will not work as well as the others in that application. The seafoam product is a multi-use product that is not specifically engineered for that application. In their marketing material it states that it can clean the fuel system, but it really does not have the ingredients that will clean the internal parts in the fuel system including the injectors.
---------- Post added at 07:39 AM ---------- Previous post was at 07:36 AM ----------
The owners manual for my 2011 recommends using the GM fuel system cleaner at every oil change interval if you do not use top tier fuel. I did a search some time ago and found out the GM Cleaner is the Chevron Techron. I bought the Techron at Walmart. They only had the small bottles that treat about 12 Gal (can't remember exactly) so I put 2 bottles in and filled up. Was about half the cost of the GM branded cleaner.
Isn't it funny that when GM has a product with their name on it, it now becomes okay for that type of service. I think some day you will also see GM Transmission Flush, Coolant Flush, Brake Flush and Power Steering Flush. Al lot of dealers are offering these services now along with a warranty coverage from the company that provides the chemical products and the service machines. The dealers make about a 50% margin on these services which adds some labor for the tech and more $ for the Parts and Service Departments.
Meccanoble
Georgia
Its been 4 years. Do we recommend Chevron fuel cleaner still? Interested in buying but dont want to hurt anything.
adventurenali92
Big Bear Lake, ca
So this was interesting thread to read through. My 2006 Denali is at just under 93k and im doing everything I can to make sure my rig is in top running shape, especially as I'm nearing 100k. I'll be do for an oil change when I hit 95k which will be in just a couple months. Should I look into this with my next oil change?
What qualifies as top tier gas, out of curiousity, what companies are deemed top tier?
AppocAlexx
Darth Appocalexx
Abilene TX
BG products are top o the line for me. Always works well with lubricants and additives. I have had good luck with the Lucas Oil trans and engine additives also.
jrobie79
Chevron, Gumout Regane, Redline Si-1....anything with PEA is good, don't waste your money on anything else
BADRIDES
At the dealership I work we sell the BG fuel additive like its going out of style. Also sell a lot of Lucas oil additive.
Tim Quigley
Kingston NY
Ive tried a lot of cleaners, and I think the best one I have used by far is the Gumout. It's an orange bottle and there's a few different ones, high miles , complete fuel cleaner or just fuel injectors
robos
