97blueyuk
- Joined
- May 5, 2013
- Posts
- 74
- Reaction score
- 2
My 97 Yukon 5.7 vortex is not starting.
This all started after I fixed a cracked fuel line near the tank. The fuel pump is only about 3 years old and I can hear it running when key is turned on.
After I fixed the cracked line it was fine for a day or two. Then it started giving me issues starting and I had to use starting fluid. I though maybe the filter needed changed so I changed it. After changing it it would not start. I double checked the filter was going the correct way. I pulled the filter, had gas coming out of both fuel lines ( back from the motor and from the tank). It seems gas is getting to engine but not starting. Spark is fine. I was thinking pressure regulator/spider injector but would like some opinions before going through taking it all apart.
Thank you
Thank you
