Fuel Pressure Regulator Replacment
I
insadj05
Iowa
Well my best guess is it was light brown from no fuel instead of darker brown from fuel being burned.
I
insadj05
Iowa
I just found a case study :http://troubleshootmyvehicle.com/gm/4.3L-5.0L-5.7L/spider-fuel-injector-misfire-case-study-1
that kinda explained what was happening. Not sure I can do all of those tests that he's performed, though I thought I would at least remove the injector and turn the key on and see if it's spraying constantly or not. I'm not having any trouble starting and the plug isn't wet. I contacted partsgeek and they cannot send a specific injector, I have to take the whole thing off and get a new one. But I wanted to at least have an idea before I did all this if it's really the spider or something else.
I
insadj05
Iowa
Mystery solved
Started pulling the intake back off and pulled the wiring harness off from the top of the fuel spider. Looked down and saw a bent wire that I hadn't seen before. Straightened it and reassembled what bolts I had removed. Removed codes and started it. No Misfire.
Thanks for all your help. Now on to the xfercase or front ujoints which ever it is.
:drink_nl:
