2007s do not have a Fuel Pump Control Module. The pump is controlled by the ECM and a relay like in the previous generation and pressure cannot be seen with a scan tool.2007 Tahoe 5.3L Flex Fuel - some hesitation when accelerating. Periodically throws p0300 - indicates lifter replacement as fix.
There isn’t a loud tick typically associated with collapsed lifters. Talking with a GM master tech, suggested testing fuel pressure before performing lifter DOD AFM delete.
Testing fuel pressure - 59-60 PSI while running - when relief valve is open drops below 30 and doesn’t recover.
Testing with key on engine off - 59-60 PSI. After 25 minutes pressure drops to 35 PSI and continues to drop.
My question is - what is an acceptable loss of pressure over time? Would this be an indication of a bad fuel pump?
Any ideas or advice is great!
Pictures showing PSI before and after relief valve is open - engine is running.
Key on (might have to do this several times to get highest pressure), pressure is to be between 50-60 psi and not drop more than 5 psi after one minute.
Here is a description of how the 2007s pump works:
