Thank you for this - is there a somewhere I can find the basic maintenance schedule? I think it’s a good idea to start on that while working to figure out this issue.
I bought this at 124k in 2018 - I had not done any work on my vehicles other than an oil change. Since buying this thing, I have replaced/fixed the following: rear differential, front end suspension - upper and lower control arms, inner and outer tie rods, struts, rear air shocks and compressor, in and out heater hoses, radiator hose, plugs and wires 3x (I have since learned those need to be replaced more frequently), alternator/power steering pump bracket, battery - all of this with continuous issues cropping up. So, I think starting to get after the basic maintenance would be good to help avoid further issues compounded by not completing scheduled maintenance.
My next job is transmission maintenance and what you have listed above.
Can you tell me what f/p (fuel pump?) carbon canister and fuel tank lines blown out means? I assume to clean or “blow out” crud that has built up? Do you have advice or process on how to achieve this process?
Again, I’m learning to be patient and not just throw money at it but take the time to do the necessary work to get back to status quo.
I do appreciate all the help I have received - it has saved me hundreds and hours of work.
