HK-DEMON-
Does anybody know the exact fuel pressure for a 2001 Chevrolet Tahoe with a 5.3L, LS,?
I got some info out of the Haynes automobile manual but im not really sure if its the correct info. It states in the manual that the fuel pressure should be 55-62psi while the key is ON and should drop about 8psi while the engine is running. My gauge reads 22psi while the key is ON (i tried the on and off method to raise up the pressure out of the fuel pump but didnt work) and drops down to 10psi while the engine is running.
Im having an issue with throttle response while im driving, and also during idle.I replaced the fuel filter and air filter. I cleaned out the Mass air flow sensor and throttle body with a "special" spray.
Any one have any clue to my problem?
thanks
thanks
