Gas Cap + Engine Light
Vortecmass
Can anyone tell me how to fix the problem with the gas cap and my engine light on?
In have replaced the old cap for a factory new one and I was hoping this issue will be fixed, but it didn’t.
What else can i try? I don’t have the code with me but technician says is something wrong with the gas cap.
07’ HOE LS 4.8 L 2wd
ccapehartusarmyINF.(ret)
Gilbert AZ
okay how did you know to replace the gas cap without pulling the code becuase a faulty gas cap is related to the evap emissions system wich would be a p0440 or p0442 p0446 etc
find out the code is because if you have an evap emissions code the gas cap is only one of a couple things that could be wrong the gas cap is the first thing you replace in this situation becuase its the easiest and the cheapest
also once you replaced the gas cap how long did you wait for the code to clear becuase it takes quite along time for the drive cycle to complete before the evap system is tested again
t.stimpson
i agree. Its probably a bad evap emissions part. Its a common problem. The parts are cheap
JML07denali
You should be able to reset the check engine light with a obd II scanner. Or autozone can do it for you.
Gilbert AZ
like i was saying the requirements for hte evap system to be tested again IE the drive cycle can take awhile and when you clear the code everything starts all over again
joo3yy133
