gas leak above tank
07HOE4x4
Hi. the leak is not bad yet...Haven't pulled the tank yet, but it is definitely coming from above the tank...wanted to know how long it takes to drop the tank and if it is pretty easy or hard to do. I realize that is relative to your time, tools and mechanical aptitude. I have a good friend that has most of these :) So we were curious about the job and if it is a nightmare or a reasonable repair...and any kind of estimate of time to drop it-disconnect hoses and that kind of thing...thanks for the help guys-GST
fiatdale
Houstons Best
Houston
Probably coming from your fuel pump. Its not hard to drop the tank, just be very careful, preferably with not much fuel in it. Disconnect all lines going to the tank and the two straps also. If you live where there's salt and rust, the straps may need to be cut off - so be prepared for that (new straps aren't much $$ either). lower the tank with a floor jack and a block of wood SLOWLY and remove from the vehicle.
The lock ring can easily get rusted up and be a complete pain in the ass to remove, but it will come. Remove that and pull the pump. I'm willing to bet that's where its coming from - sounds like the same issue I had on my 07.
In terms of time - definitely a few hours, probably more if you have never done this before and the lock ring is stubborn. Just don't puncture the tank trying to get the ring out!
Use a GM pump too. Its worth it.
07HOE4x4
07HOE4x4
Thanks a bunch for the info, fiatdale! Have a couple more questions, but I'll write more later. Reallly appreciate the post. Thx!!
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I replaced mine last summer. Fuel lines that run into the pump corroded. Any time the key was on, it pump gas all over the place
FuzzyChopz
Same thing happens to me. One of the fuel line elbows rushed out. Just replaced mine two months ago. Buy an ac delco pump and new lockring just in case. Try use all of your gas to make it lighter, and if you plan on cleaning the inside if debris has gotten inside. I used a YouTube video to help me out. There are a couple good ones on there that show you where and which hoses to disconnect. I think one was by A1auto. Also it is so much easier to remove the tank strap bolts if you have air tools. One last thing make sure you make sure the pump works before you bolt everything up and make sure it has at least 3 or 4 gallons of gas in it or it may not start. I put in a gallon and a half and it wouldn't start without putting more in. Good luck!
07HOE4x4
07HOE4x4
Use a GM pump too. Its worth it.[/
To All that are on the thread,
I am not sure if this is the correct way to use the forum, but act first and ask for forgiveness later, Right??
so I have learned a little more since yesterday, but not enough.
Q's: 1) how did (do) you know that the fuelpump is the leak? CEL?
BTW, my hoe is rusty underneath....
I get a CEL, if the tank is fuller...and now that it is under a 1/5 or 1/6 of a tank, it has reset...
I test drove it- above 1/4 tank, got CEL, but by the time I was at Autozone for a code read, the dam thing had reset... so I never did get the code
Point is-I don't know REALLY NO where the leak is originating from...
2) did you KNOW where the leak was before you dropped the tank?
3) Are these two motors interchangeable??
this is copied from the autozone website;
IT FITS. This product is a fit for your: 2007 Chevrolet Truck Tahoe 4WD 5.3L Flex Fuel OHV 8cyl
^ my hoe is NOT a Flex Fuel motor...GAS ONLY!!
Autozone has a 3 pumps available- here is an ac delco
http://www.autozone.com/fuel-systems/fuel-pump?filters=50002-4294853337
LOCKRING
http://www.autozone.com/fuel-delivery/fuel-tank-lock-ring?newYmme=true
4) how do you repair one of those lines, if it is bad?
rubber tubing? rig it? have to order the lines?
5) do you just buy the
-PUMP
-LOCKRING
-AND anything else, before you start the job...SO YOU HAVE "on hand" WHATEVER THE PROBLEM requires????
I am working today, so I will reply asap but may be waylaid :)
So, there you are :) Start with the most obvious in your mind...
Thanks
07HOE
07HOE4x4
07HOE4x4
Here is the animal from autozone-I called the chevy partsman and got a GM OE #19168418...then autozone said that it was the exact fuel pump with the sender. Ordered tonight-suppose to be in tomorrow. Buying a lockring too. I think the only thing I need to find is one of those gas line splicer connector kits...Autozone didn'tonly had one for the AC...
I am working on getting the air tools and spraying down the rusty bolts
and strap housing...
And is this "NYLON" hose repair kit acceptable?
Do you know what size hoses are on the hoe?
Thanks for the help guys!!
07HOE4x4
07HOE4x4
and the lock ring. ...and I'll return anything I don't need...
ehernande86
