General CB Radio advice.
the big blue bus
richmond, va
so i have the cobra 19 mounted on the ash tray door in mine. the antenna is on the left rear. i have a 102 whip and a crappy spring. i want to get a good whip spring but right no i dont get the best reception. i barely use it but when we are all convoying id like it to work better. i dont know it its the bumper has a bad ground? or that my radio needs to be tuned somehow? my other buddies have the tunable cobras but for 30 bucks the 19 works for me and has the pa function too. would a ground strap from where my stud is mounted to the bumper to the chassis ground where the lights ar grounded help aid in reception? would the taller spring help too? sorry for all the questions. wlill get pucs of my install tomorrow
LittlePearl13
LittlePearl13
The Central Coast (SLO county), California.
From the experience and knowledge I've found out about, the bumper is a bad place for it. Every antenna uses the piece of metal it's attached to for the ground plane. The better the ground plane, the better the reception. My ground plane is my entire roof. A numper mounted one just uses the bumper. This is bad because it a) is much smaller = worse reception b) covered in plastic up top = worse reception and c) the antenna is mounted low, and askew. If you look back to one of Edzaar's links, you can see how that can negatively affect the antenna's signal. Basically anything that is around the antenna's lateral plane will disrupt it's field. My antenna was mounted right behind my light bar, and once I moved it back so it was as far away from roof racks and stuff, my reception got even better. Another reason you probably have not-so-good reception is the ****** spring. Anything that you put between the antenna and the other end of the coax cable (where it plugs in) will weaken your signal a little more. This includes springs, disconnects, etc. You were asking about tuning it: yes, you should tune it. n fact, everybody should tune every radio before the really use it for even mild functionality. Don't bother buying a 'tunable' radio or an antenna with a tunable tip. My friend has one, and the limitations of his tunable antenna prevent him from getting the right SWRs. How you want to tune the antenna is with an SWR tuning meter. All it is is a little box with a meter and two coax cable connections. One is where you plug in the antenna, and the other is where you plug in a short jumper coax that you then plug into the radio. You can buy one on Amazon with a jumper for like under $20. Let me know if you need more help once you get this stuff. Or Edzaar, haha, he knows more than I.
But still, I know more about CBs and how to make them work well than all the trucks you see driving around with a firestik mounted up all jammed between the cab and the bed and don't tune them -_- Putting them right behind the rear window on a pickup in the least functional place for it. Anyway, hope this helped. And if you need some real solid advice on your specific setup, hit up a local Radioshack and they normally have at least one employee who's an expert on CBs who can help you a lot. My guys saved my ass and helped me get a really good setup going on. I've got a cheap radio, and a cheap mag mount antenna, and I still get really clear reception up to San Jose, CA... which is almost 200 miles from where I live.
rushr
Illinois
It's been a long time since I've been into CB Radios, probably about 13yrs or so...I still have my old Galaxy Mirage 44 though, I may have to look into putting it in the Yukon. I also have a small Super Star 250 Amp, but I'm unsure if it still works. My Galaxy started out as a Ham Radio, but it's been clipped and now has over 700 channels if I remember right. I had it set up as base unit in the house, talked from Arkansas to New York and Colorado depending on the time of year off of radio power alone. I used to go by Arkansas Outlaw...lol
the big blue bus
richmond, va
i dont want to buy a new antenna and moutn in on the roof i know it would work better but ive allready got the whip on bumper and dont want roof mount hitting braches and stuff all the time. if i run a ground cable from near the mount to the frame ground i think it may help. also i want to get the 6" spring for my whip and take the crappy one off
psfr311
Lawrenceville, GA
i have a 5 foot firestix antenna mounted to the passenger side of my rear bumper with a "gumdrop" mount. havent had a single problem with it.
LittlePearl13
LittlePearl13
Even though you may have not had problems, but if you ever find a handheld cb, you should test it on your truck and see which directions it transmits best. (hint: it will be rear corner)
Big Blue, if you go that route, make sure you retune the antenna. Changing the size of the spring changes the tuning.
LittlePearl13
LittlePearl13
Mine's a whip too. Normally at the bottom the antenna part (just the thin piece of metal) is attached to the base, and normally there's like a little cone to adjust the height. you just change the height of it in the little cone, and if you don't have enough room, then you cut the bottom of the antenna. Just by like a millimeter or so. It's not to hard to do, it's just tedious.
bobby88
