Getting so sick of a bad ride in the tahoe
N
Nickleahy23
Portage/Menomonie, WI
what rear set up are you running right now i forgot?
what spring/shock?
your on shock extenders right?
no rear trailing arm/swaybar kit right?
belltech springs i believe..same ones max ran forever and is going back to..helper bags in rear..
shocks in rear are new stock shocks with extenders, front shocks are orig shocks, i know they are shit..
no kit for the rear yet..i just sent you a pm
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no prob honestly for now I would do
front djm a arms
front djm shocks
rear djm hardware kit
rear spohn adjustable arms.
If your set on the belltech springs and want to try out shocks go for it. If your still not happy after you test new shocks we can try the tb 4 inch spring/djm shocks which im sure you will be happy with
polancop
I just got the 24 inch Boss rims recently and the ride is horrible around 60 mph, not sure if that is common with the rim and tire size (305-35)? Is your ride rough all around at diff speeds? I still have the stock suspension, 07 yukon.
N
Nickleahy23
ride is honestly the same stock rims or 24s...my shit is so ******...it clunks front and rear right now, clunks when brakeing and giving it gas lol...i dont have the time or the place to even put it on the lift right now to check it out..hopefully soon
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
tb 4" springs ...... cure to all the worlds problems lol
Jk man hopefully you figure out what the problem is.
thor1125
orange county
why would the rear sit 1/2 inch higher if your getting more drop with the tb springs...
felixgun
Lafayette, LA
I feel you pain, I have the 295/35-24's also and the ride sucks. I need to change shocks to see what that does, but I think it mostly has to do with the low pro tire/wheel setup.
I have 305/35/24 and it rides almost as smooth as the factory tahoe ltz 20s... What's affecting the ride quality?? The drop or the rim/tire combo? Bc I have no drop but my rim/tire combo is not affecting my ride quality by any means. Of course slower take off and harder braking is there but that's because of the size/weight of the rim....anyone anyone??
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
most likely the tires there is a difference on ride from one brand to another.
felixgun
Lafayette, LA
Even though we both have the same sidewall size? I was actually debating doing a 2" rear drop but didn't want to lose any ride quality...
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Kumhos ride a little harder than other brands and as for lowering id do 2/3 on your truck will ride fine. if you only want to lower the rear 2 inches id do the belltech set up.
Andre Mallory
