GM 6L80 Transmission Information Thread
S33k3r
Dallas, Texas
With taller tires you are also going to want taller (numerically) gears. Otherwise you are losing mechanical advantage. It's great for highway gas mileage, but not so great for quick acceleration. There's an article in my signature with a chart.
ilikemikes
Austin, TX
Just getting back to this Nick, thank you sir! I will ask for some specifics. Was just talking to my neighbor (ex-mechanic now engineer), he thinks the Billet torque converter is over doing my stock engine and for the amount of towing I do. I tow my bass boat once a week 30 to 100 miles. Its maybe 3500lbs. The Tahoe is currently a little sluggish while towing the boat and would like some pep. Thoughts? Thanks again.
Got some details Nick...
✅ 6L80 stage 1 2800.00 18/18 warranty ✅ Best bang for your buck in Texas! : ✅ new Florida brand carbon clutch torque converter ✅ proprietary heavy duty 4-5-6 drum set up with borg warmer friction plates and thick steels, (only lathe machining the parts can achieve this) ✅ modified boost system for quick pressure rise ✅new oversized pressure pressure regulator valve ✅Performance built valve body with torque converter valve update, end plugs, AFL valve update, and vacuum tested for tolerances ✅lathe machined like new pump stator ✅ Case is sand blasted and coated with automotive grade paint and clear ✅ cooler flow pump modifications to keep stock or 40k coolers at max efficiency! ✅ OEM dealer , gasket, o’ring, and screen kit for TEHCM ✅ TEHCM fully tested and programmed to your tire size and gear ratio , also includes new aftermarket software for longer torque converter durability and zero shudder issues! ✅ zero snake oil parts ✅ firm shift tune available upon request at no extra charge, otherwise transmission will shift smooth. ☑️18,000 mile 18 month warranty on entire transmission including TEHCM/computer, with invoice and serial # DECAL unit built by diesel Master ASE certified, ATRA instructor Pepe Torres building performace unit since 2005! beware: all of our units include a serial # with flag and logo for identification Beware of copy cats PRO installation special is 1200.00 Includes HOT FLUSH machine that flushes transmission cooler/s, full synthetic fluid fill, computer adapts reset and road test
Sparksalot
Bastrop County, Texas
Which shop is this?
NickTransmissions
The transmission bench
ilikemikes
Austin, TX
These folks?
$2800 is for a complete overhaul, torque converter plus $1200 r/r so 4$k...not bad if so..
Yes sir. Aus-Tex Transmission. They have great reviews and seem reputable.
Am I overdoing it by getting the Billet torque converter?
YukCCR
I hope this is the correct place to ask this question, if not I apologize. I just had my 6l80 transmission replaced on my 2007 Yukon Denali with 147K miles by the chevy dealer Bill Roberts Bolivar MO, for $5600. When I got it back yesterday, I tried the manual shift mode and it does not do anything. I called the service advisor and he said that had nothing to do with the transmission, that it would be a problem in the buttons on the column. So, if I take it back it will be more money. Should I try to troubleshoot myself using the videos and 14 pages of posts on this forum, or should this have been part of the replacement?
YukCCR
To clarify the history - the shifting problems began around the first of this year, and the manual shift mode stopped working at the same time. The two shops I took it to prior to the dealer both said it need a transmission rebuild or replace. They did not say that the manual shift mode, which I noted in my complaints, was a separate issue that would not be solved by the transmission replacement. I went with the dealer trans because of the warranty.
began
ElMasBuscado23
