Got some details Nick...
6L80 stage 1 2800.00 18/18 warranty
Best bang for your buck in Texas! :
new Florida brand carbon clutch torque converter
proprietary heavy duty 4-5-6 drum set up with borg warmer friction plates and thick steels, (only lathe machining the parts can achieve this)
modified boost system for quick pressure rise
new oversized pressure pressure regulator valve
Performance built valve body with torque converter valve update, end plugs, AFL valve update, and vacuum tested for tolerances
lathe machined like new pump stator
Case is sand blasted and coated with automotive grade paint and clear
cooler flow pump modifications to keep stock or 40k coolers at max efficiency!
OEM dealer , gasket, o’ring, and screen kit for TEHCM
TEHCM fully tested and programmed to your tire size and gear ratio , also includes new aftermarket software for longer torque converter durability and zero shudder issues!
zero snake oil parts
firm shift tune available upon request at no extra charge, otherwise transmission will shift smooth.
18,000 mile 18 month warranty on entire transmission including TEHCM/computer, with invoice and serial # DECAL unit built by diesel Master ASE certified, ATRA instructor Pepe Torres building performace unit since 2005! beware: all of our units include a serial # with flag and logo for identification Beware of copy cats PRO installation special is 1200.00 Includes HOT FLUSH machine that flushes transmission cooler/s, full synthetic fluid fill, computer adapts reset and road test
