Going through CV Axles!
Jtagle77
Buckeye, AZ
Anyone ever had any problems breaking CV at the inner joint on driver's side only? Seems to only break when my wheel is turned and in 4Lo. I don't do any major off roading, I jusy use it for hunt and fish trips. Here our the Yukon Specs. Thanks in advance
98 Stock 5.7
2.5" Rough Country suspension lift
diff drop brackets
new wheel bearing hub assemblies
new bump stops
Gzes
the drifting 2dr
Wichita tx
It's possible the suspension lift is causing a weird angle which can snap stuff easy. Post pics and we can go from there. Do you hav a 2dt or 4dr?
Donnie Yukonie
Yates Caretaker
the 2.5 inch lift is normally just blocks and keys however you state it has a diff drop , x3 for pics
shadowid60
