Tell me if I have this correct...
2 outer and 2 inner tie rod ends
1 pitman arm
1 idler arm
2 idler arm brackets
Is this correct?
Also should I replace the center link? It says its a non wear item on rockauto
And I only own one puller this one http://www.amazon.com/Great-Neck-OEM-25297-16-Inch/dp/B004FEPCWS/ref=sr_1_1?s=automotive&ie=UTF8&qid=1389922727&sr=1-1&keywords=oem+25297
Is that the only type puller I need to do this job?
thanks
1 pitman arm
1 idler arm
Is this correct?
thanks
