My hood-cowl seal has shrunk (shrank? Shrunken?) over the years. This is how short it is when pushed all the way to one side:
I got one with much less wear (less squashed flat) and shrinkage from a newer Tahoe. I first planned to cut my original one in half and use half of the newer one to make it span fully and firmly. But, the new one was longer and "close enough", so I installed it as-is. This eliminates having a seam where two differently-squashed seals would meet. This is how much less shorter it is, I centered it after this pic:
I then moved on to disassemble the left rear window switch and clean the contacts to restore its operation. Finished up by adjusting the tire air pressures because I want all four to read the same on the DIC.
