Handling 101
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Honestly with the autoride the 5301 and 5305 springs ive been very happy with.
soulsea
soulsea
Bar
What's the difference tween the 5301 and 5305?
Goodinblack
I Like Tacos
Dirty South
I think autoride and 2 inch springs is the ideal set up.
The high back end looks soooooo ****.
Adjust the links for a .25 inch rake and perfection.
If I was Serge and picky like him I would leave the the front alone for starters.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
The 5301 coils are a 1.5 drop rear on a autoride truck. the links you will need to do which I can help you out on. very easy
the 5305 is the ones you need shock extenders for they are adjustable from 2-3.75 on autoride.
soulsea
soulsea
Bar
The 5301 coils are a 1.5 drop rear on a autoride truck. the links you will need to do which I can help you out on. very easy.
This is exactly what I want, a simple 1.5" rear drop that will level the truck, that will trick the autoride/MRC, and won't light up my dash.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Im actaully redoing a truck this weekend that a shop messed it up completly. The autoride links are stripped and the shop just took them out. If you want some pictures or videos just hit me up I can show you how to make the links and get it all ready so if you decide to put springs in will be a easy trouble free swap.
Goodinblack
I Like Tacos
Dirty South
I have those 5301s. I like them a lot.
---------- Post added at 10:52 PM ---------- Previous post was at 10:51 PM ----------
I am running the 1000s too since I don't have Auto Ride
soulsea
soulsea
Bar
Well, I'm not much of a doityourselfer. :)
But if I decide to buy the springs from you can I also purchase a set of modified links from you at that time?
Will I still need shock extenders, DJM links, panhard, for such a small drop?
Blazed
Accepting Donations
Do you know what they did to cause the links to strip.
WingsAA
CMFIC
Dallas, TX
I have the Hotchkis front and rear sways. I installed them a few years ago before I did Tony's 2-3/4 drop. Blazed explained it best. You might notice a rougher ride over bumps, etc but my suburban cornered on rails. Since the drop... it's insane how well this thing handles corners at high speed and this is coming from a guy that has a track prepped E46 M3.
Regarding the shorter rear end links... I have them but have never installed them. The Hotchkis rear bar has a slightly different design and thus comes with slightly shorter links with the kit. They are not as short as the links I got from Tony but I had some trouble getting the shorter links from Tony installed due to the design/angle of the bar ends. You'll see what I mean when you get it. Once the weather warms up here, I'm going to give the shorter sway bar end links a try and see if I can take my time and get them installed.
