Hanging Wire ! Help!
Hype
Land o Lakes, FL
I noticed this wire hanging down from under the dash its behind parking brake and obd2 port. nothing is acting up to my knowledge and im too big of guy to get the right angle to see where it hooks too... I was wonderin could help? its on a 2003 Yukon slt
Rivieraracing
Dang, wish I knew! I might be getting up under the dash of our truck this next week so I'll try to help you figure it out unless someone else chimes in! Is that wire light blue?
Hype
Hype
Land o Lakes, FL
thanx, and yes its light sky blue, if u have a rear defog its same type connector that uses to connect to contact on rear glass...
ScottyBoy
Shreveport, La
That's your parking brake wire. It should be plugged up to a spade connector on the back of the parking brake housing. That's what turns on the "BRAKE" light on the dash when you have the parking brake on. With it disconnected, the brake will still work and all, but that warning light on the dash will not be on.
Hype
Hype
Land o Lakes, FL
thanks for the reply, Well that explains me discovering the parking brake has no tension and just flops down , I just got this truck 2 weeks ago it didn't even go thru my mind to check that brake as I don't use it much at all in florida with no inclines.... but they must have broke the brake then disconnected the wire for light so the buyer wouldn't notice.... is this fix expensive?
MrBalll
West Texas
Depends on what's broken about it. Just the cable hooking to the the pedal and going out of the vehicle to the underside is about $20 so not too bad.
Again, just a matter of checking what's wrong.
ISU-152
Lol the shady things people/dealers do. Personally I'd rather just know what's wrong
Dnozgodlike
