Hard wire radar detector.
KMeloney
Use this:
Pop off the center piece under mirror on windshield, the disconnect plug. Plug in new connector and boom your done. Did it to my '22 Tahoe.
Search fro Radar Detector harness for Tahoe "your year".
Do you have a tried-and-true method for removing the plastic housing at the mirror/windshield? I'd like to go this route with my hardwiring, but I'd have a good chance of damaging the plastic housing without some really good instructions.
chrisbusnut
Portland, Oregon
Use this:
@VPVETTE , do you have a link for that harness? And how did you remove the plastic center piece? I agree with @KMeloney ...I'm afraid I would break mine removing it.
DenaliCountry
Buy the mirror harness. It's like $35-50 and takes 10 minutes to install.
shekmark
Jersey Shore
Re-opening this thread. Any tips on removing the centerpiece without breaking anything. I’ve also been staring at the harness I bought a year ago.
P
Padraig
Can't help with centerpiece adapter but it was very easy to run wire from fuse box to just past the center. The cover on the passenger side pillar comes off very easily. Run the wire up to the head liner and then just push the wire up and into the head liner. Easy peasy. That centerpiece scares me. LOL.
Padraig
KMeloney
It took me a while to get up the nerve to tackle this, but it ended up being really easy. That piece is relatively flexible, and just requires a finger wedged under the side while you also push a little toward the middle of it, and you’ll free up the clips pretty readily.
You’ll start with your hands on both sides of it, and be freeing up the end farthest from the headliner first. Then it comes away from the headliner. With your hands on either side of it, and by flexing a side inward (and allowing for a bit of “side to side” motion of the piece) to get your finger behind it, you’ll free up the piece easily. As I recall, the piece essentially seats “around the sides” of retainers as opposed to having male clips press straight into female openings— so, you don’t want to get in there and just pry away from the windshield toward you. You want to essentially free up the sides with a little side-to-side flexing/motivation.
Once the main piece is dislodged, you’ll tilt your mirror stem down and tilt the plastic shroud down so that you can see into the inside and be able to locate the tabs that the small center section piece uses. Those tabs are small and delicate, but it really is easy to push the tabs out of the way to unclip that piece. Once that’s out, you can pull the larger piece off altogether.
arto832
