Has anyone converted back to straight gas
OR VietVet
Multnomah Falls
Military
Willamette Valley
I'm not sure I understand what you mean by "3rd member design". However, RWD and 4x4, not AWD 1500 GMT-900 SUVs with the 6.2 and 6.0 Hybrid received the 14-bolt 9.5" semi-floater rear axle versus the 8.6" used by the 5.3s and the 6.2s with AWD. Within this same generation it is a plug and play affair and one does not need to open them up (parts replacement) unless they want to change the gears.
I misread your previous statement. You were talking about used price of about $400 and drop it in in the afternoon and I did not pick up on you were talking about a complete axle. When you said drop in my mind went to a third member differential, like a Ford 9" diff. Instead of building the gears in the housing a Ford third member is a complete unit that just unbolts from front of rear diff and lifts the whole gear assembly out and then "drop" in a whole different gear assembly/section. Since I have been away from shops for a while I thought something weird happened and GM was making the 9.5" semi float set up as a third member. I am old. Need to read better before replying. My bad. :(
OR VietVet
Multnomah Falls
Military
Willamette Valley
I could live with that...love the way the hybrid drives that much...really wish I could upload this video....it keeps telling me the file is too large and Ive trimmed it down to 5MB...it was 40MB...if it really is the rear end...I need to research if there are any repurcussions to changing the gear ratio at the same time...I would really like to run a 3.73 gear...I have this on my monte carlo ss...with a 700r4 and really like the results....thanks for the advice...ill know soon for sure after the dealer looks at it.
You need to set up and download at you tube and then post the link. It took me a while and my bosses son to help me figure it out but it works. Remember though, I am almost 67. If you are under 40 years old you have no excuse for not being able to do this. :D:chewie:
Dropped HYbro
49 going on 25 years of age...LOl...im not sure I want to post anything to youtube...let me see if I can use my sons acct.
Bigkevschopshop
Northside H-Town
Ok... PUt the rear end up on jackstands, chock front wheels, Here is what I want you to do... The place where the driveshaft bolts to the rear end, Grab it with your hand, try to move it up and down. This sounds like a pinion bearing explosion, I have had it happen on a gm 12 bolt, under load all kinds of grinding and banging, reverse and decell no noise.. When you do that while in the air, rotate one of the tires go forward and then go backwards, watch that yoke off the front of the rear end, see if it moves in and out vs the housing staying stationary. I am just an old hotrod mechanic not a "technician" so I may be on the money or off the money.
Also if the trans is in neutral its pumping, if in reverse its pumping, so i think the pump is still good and your getting no noise in those two gears.
Dropped HYbro
good morning ...quick update...truck is at the dealership now....will be getting looked at today...im hoping for the best.
I did try a few things before the tow truck...which by the way ended up being a wheel loader because I would not let the driver drag it up the flat bed...ugggh...strangest thing...jacked it up in the rear on tire moved back and forth the other side nothing...locked up...played with it (many clanking noises)...got them both to turn...set down and was ready for the tow truck to pull it up....nothing it seemed like the front then seized up???...which is crazy considering its a rear wheel drive 2WD...ill post when I get more info from the technician.
Dropped HYbro
so heres the update...dealership says that the rear end differential is done...shot out and needs a total tear down and rebuild....they have quoted me $700-900 for parts and a total labor time of 12 hours which translates to $1400-$1600....best case$1700...worst case $2500 with a 2 year unlimited mileage warranty....I know this is not a good price for this work...all my research shows its a 5-8 hour total tear down and rebuild...I don't feel confident enough to do the repairs myself...though I do know a little about rear end differentials...I just don't have the experience personally of tearing them down and replacing ring and pinion...I am going to dealership today to try and negotiate with them in regards to pricing...couple questions...please guys help me get some answers.
1.Can I go to a 3.73 ring and pinion to help compensate for the size of my wheels and tires...33.81"...about 2+" bigger than stock...will they be able to program our hybrid trucks to the new gear ratio in regards to shift points and speedometer???
2.what would make a rear end totally break down like this....my truck is a RWD 2WD....they didn't tell me how bad it is yet they would have to tear it down to let me know if there are actually teeth broken/pins etc.???
3.I really need the warranty and guarantee...what would be a fair price for this work....a total rebuild of the rear end...ring and pinion...bushings...carrier or a total tear down and rebuild using new AC Delco parts???
4.Is there any other work related to my current issue or problem that IU should have fixed or serviced while the work is being performed??
all comments and responses are really appreciated guys...just love this truck and want it to "Healthy" again
jeffbco
Wow - expensive. If the warranty is important to you you should make sure the mounting of non-standard size wheels will not void the warranty.
OR VietVet
Multnomah Falls
Military
Willamette Valley
If it takes 12 hours to tear down and clean and rebuild, I would fire that tech. He may be good but I know a local guy here that I was in a shop with and he can do that job, easy, in 6 hours. If you go with the dealer that price better include new axle bearings and seals.
Dropped HYbro
I'm going to the dealership today and try and negotiate a more reasonable cost to do this repair...the truck is mechanically in great shape...and I know sometimes things happen....I just don't feel the price is right on this....I just want my truck back...well see what happens.thanks ron.
OR VietVet
Multnomah Falls
Military
Willamette Valley
In case you missed what I was saying, the axle bearings and seals should be replaced because of the shrapnel flying in the bearings when the diff grenaded.
Nemo_B4
