Has anyone installed their own heated seats?
deangrell
Sweet! I might tackle this soon. As for window switch module, it is SIMPLE to pop out without scratching. Especially with plastic tools that you mentioned. Thanks for the info! I'm sure more folks will be inclined to try this now.
snowjay
snowjay
Yeah, I'm sure it would of come out easy, but to pop it out remove all the connectors just seemed like a waste of time with a slight risk of damage. Once you get the door panel popped off there are two "arms" that stick out on the bottom that you can rest in holes in the bottom of the door so it's supported and then you take off the handle, put in the new one, rotate the panel 90 degrees and plug the new connection in. Rest door back on the arms, reattach the cable for the latch and put the panel back on.
The whole process wasn't that bad, only time consuming. It's been a long time since I worked that much on an interior of a vehicle. I have to say GM engineered things pretty well as far as ease of installation and removal. With nice fits and tolerances.
BTW, these are the tools I got: http://www.amazon.com/Actron-CP5011-Panel-Molding-Removal/dp/B000VYBLJ4/ref=pd_sim_hi_15
15 years ago they didn't have anything like that, only metal removal tools that you used to wrap in masking tape. I couldn't find that old tool (probably for the best) and bought the ones above.
When I scan the instructions I'll try to include some notes on some of the sections.
Mauro
Fresno State Bulldog
Fresno, CA
When you scan the instructions could you include the pickup instructions? I'm wanting to put these in my silverado, you can just PM me if you don't want to post them all....I think the excess cable is because on the non-LTZ interior pickups, the switch goes in the dash, see the pic below :D
snowjay
snowjay
Yup, I'll include them. It's actually not separate instructions, they are all the same but direct you to certain step numbers depending on your application.
VikingFan
Minnesota
This is a great thread. It got me thinking about my wife's request to have heated seats. So I checked out the link provided and looked at the option of the $150/pr seat heaters. I called up the local upholstery place and asked what they'd charge for R&R of the leather if I pulled the seats. I was quoted $180 if I did the wiring. Which is not big deal since I was in car audio for several years. However he did tell me that he has a kit he'll do for $400 installed. I drop the truck off in the morning and it'll be ready in the afternoon. For an extra $70 that seems like a nice deal.
I remember taking off leather years ago and having to remove and replace all those metal d-rings. I don't even have the tool to do that anymore. Maybe the new seats don't need it but for a couple hundred bucks I'm willing to save myself the aggravation. Especially if it took you 6-8 hours. I'm all for DIY but this sounds like one I'm willing to pay for. :)
zach2011
Platinum Member
I wonder if this can be done to the 2nd row seats...maybe even 3rd. :D
VikingFan
Minnesota
You could do this to them both, although on the third row you'd need a quick-disconnect for the wiring so you could take the seats out.
CIATAHOE
Orange County, CA
Pretty easy to do yourself. We get the kits from roadwire, run about 160 for the 4 heater pads and the switch etc. All you need to do is have basic knowledge of wiring and remove the factory seat covers and install.
---------- Post added at 10:28 AM ---------- Previous post was at 10:26 AM ----------
Oy yeh, when you take the seat covers off, they are all velcrow from factory, they do not use hog rings anymore.
shundal
NorCal
Any thoughts on the roadwire heating pads vs. oem? How about the switch?
BrancoRST
