Have you installed the Viper 791XV?
chip
chip
Tampa
I have alldata with wiring diagrams and pinouts. If you tell me what year and engine you have I can see if they have all of the diagrams you need. Might help if you list all components need such as bcm, pcm, dlc, and such. Just let me know.
Beautiful! Thank you!
'03 Yukon SLT/SLE
Without Onstar, but with Digital DIC
4.8L 2WD
I don't understand what you mean when you ask me to list the other components. Were there different BCMs & PCMs in the same generation trucks?
Thanks again!
ntxstallion
Don't know if they had them or not but I will pull up what I can. Most diagrams have wire color as well as function. I will try the BCM/PCM and see if that is what you need. Give me about 10 minutes.
Here is the link to the diagrams. It is every connector for the BCM, PCM, and DLC. Let me know if you need anymore.
http://www.sendspace.com/file/xj7co2
vatahoelt
NoVa
you'll most likely need a bypass module.
with the bypass module, you'll really only make about 10 or so connections to the truck. the rest is all handled through the module.
chip
chip
Tampa
That's awesome man! Thank you so much!
Can you elaborate please? I have the Clifford Blackjack to go with it as well, but I don't really want to install that in this truck. Do you have a link to somewhere that has these bypass modules?
Thanks again guys! Much respect!
ScottyBoy
Shreveport, La
You will need a bypass/integration module to interface with the doorlocks and to bypass the Passlock anti theft system so it will be able to remote start.
As far as the wiring, here you go! Here is any and all wiring info you will need for your truck.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination BROWN (+) RADIO HARNESS
Dimmer GRAY (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Steering Cntrls YES
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl YES
Radio Security YES
Security
Battery RED AND(RED/WHITE) (+) IGNITION SWITCH HARNESS
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger GRAY/BLACK (-) AT COURTESY LIGHT UNDER DASH
Domelight Super GRAY/BLACK (+) IN HARNESS AT VEHICLE DOMELIGHT
LF Latch GRAY/BLACK (-) AT BCM
RF Latch BLACK/WHITE (-) AT BCM
LR Latch LIGHT BLUE/BLACK (-) AT BCM
RR Latch LIGHT GREEN/BLACK (-) AT BCM
Trunk/hatch Trigger PINK/BLACK (-) AT BCM
Parking Lights BROWN (+) DRIVERS KICK PANEL
Low Crr Pk Lights GRAY/BLACK (-) AT LIGHT SWITCH HARNESS
Data Bus UNDER DRIVERS DASH
Convenience
Headlights-Lo PINK OR WHITE (-) HEADLIGHT
LF Pk Lt Bulb BROWN (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb BROWN (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb BROWN (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb BROWN (+) AT REAR RIGHT PARKING LIGHT
Parking Brake LIGHT BLUE (-) AT SWITCH ON PARK BRAKE
Remote Start
Ignition 2 WHITE (+) IGNITION SWITCH HARNESS
Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS
Accessory 2 BROWN (+) IGNITION SWITCH HARNESS
Anti-Theft Type PASSLOCK II
Anti-Theft Descript A RESISTANCE BASED SYSTEM
Key Sense LIGHT GREEN (-) AT STEERING COLUMN
Tachometer AT FUEL INJECTOR (-) USE THE UNCOMMON COLOR AT ANY INJECTOR
Speed Sense DARK GREEN/WHITE (AC) RADIO HARNESS
Low Crr. Pk Lights GRAY/BLACK (-) AT LIGHT SWITCH HARNESS
Brake Lights WHITE (+) AT THE BRAKE LIGHT SWITCH
Reverse Lights LIGHT GREEN (+) AT BCM MODULE UNDER DRIVER SIDE DASH
Horn BLACK OR(BLACK/YELLOW) (-) AT STEERING COLUMN
Modules
WIRE LOCATION
Module 1 BCM - LOACATED IN FRONT OF FUSEBOX
Doorlocks/Windows
Databus Wire PURPLE AT DIAGNOSTIC PLUG
Power Unlock CLASS 2 DATA (REV) AVXGMDL4 OR 5 WIRES DOOR
*TO INTEGRATE WITH THE OEM DOOR LOCKS AT ANOTHER PLACE IN THE VEHICLE, YOU WILL NEED A MULTIPLEX ADAPTER.
PowerLock CLASS 2 DATA (REV) AVXGMDL4 OR 5 WIRES DOOR
Driver Mtr Unlock TAN (REV) DRIVERS DOOR MODULE
Driver Mtr Lock GRAY (REV) DRIVERS DOOR MODULE
Pas Mtr Unlock TAN (REV) AT MOTOR IN DOOR
Pas Mtr Lock GRAY (REV) AT MOTOR IN DOOR
LF Window Up BLUE (REV) DRIVERS DOOR SWITCH
LF Window Dn BROWN (REV) DRIVERS DOOR SWITCH
RF Window Up BLUE (REV) PASS DOOR SWITCH
RF Window Dn BROWN (REV) PASS DOOR SWITCH
LR Window Up BLUE (REV) REAR DRIVERS DOOR SWITCH
LR Window Dn BROWN (REV) REAR DRIVERS DOOR SWITCH
RR Window Up BLUE (REV) REAR PASSENGER DOOR SWITCH
RR Window Dn BROWN (REV) REAR PASSENGER DOOR SWITCH
chip
chip
Tampa
Audio/Mobile Video
Accesory
LF Speaker (+) TAN
LF Speaker (-) GRAY
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
Security
Convenience
Remote Start
Modules
WIRE LOCATION
Doorlocks/Windows
******' Scotty! You consistently come through Brother! Thank you so much!!!
vatahoelt
NoVa
good luck. i'm not sure if i would even do mine myself again. i still have the window module to install and i have exactly 0 desire to cram myself up under the dash again for the better part of a weekend. lol
doc2th
