headlights don't work off switch
02YukonD
U said 2 light sensors.. I thought these trucks only had the one light sensor (ambient).
El Capitan
Senior Texas Member
Grapevine, TX
So pictured is what I have on my 01 Tahoe, apparently one is a Temperature Sunload Sensor (GM Part# 15740822) and one is a Ambient Light Sensor (GM Part# 12450120) both sensors seem identical, except for the writing on the sensor itself. Now the problem I have is I do not know which sensor goes on which side, and last time I replaced them used part number 12450120 for both. Will post update as soon as possible.
02YukonD
Oh OK... I only have the ambient light sensor.. I have to pull my my dashboard apart and check
El Capitan
Senior Texas Member
Grapevine, TX
I have another thought anyone feel free to chime in if I am right or wrong, if the day time running lights are burnt out (both) would it cause the headlamps to come on? I have 2 new pigtails from GM for them I figure I will replace the pigtails and bulbs and see if that may be the issue.
02YukonD
I put a new ac delco headlight switch in and solved the instrument cluster lighting issue but it's still not operating the head lights.. imma go out on a limb.. but I'm driving my truck without the factory key with the chip in it. I have a regular copy of the ignition key without the chip. Maybe the computer isn't reading a chip and causing some of those problems to occur.. do that sound about rite? a could that be the issue?
El Capitan
Senior Texas Member
Grapevine, TX
From what I understand if you have a chipped key your truck shouldn't start without a programmed chip.
02YukonD
U right I looked it up.. imma really have to pull the dashboard apart soon. My fog light not working also. Imma check the fuse and wiring with my test light
Jeremytahoe
