Heater hose problems, now truck won't start
1996tahoeman
I have a 1996 Chevy Tahoe with a 5.7L
I was driving hauling a boat when my heater hose that comes from the intake manifold to the heater core blew causing the truck to overheat unexpectedly. After I replaced the hose, I tried starting it and just cranks but doesn't start. No water in the oil, no oil in the radiator. What can be the problem? Any help will be gladly appreciated. Thanks
retorq
Kingman AZ
When it over heated did you turn the truck off or did it turn itself off??
1996tahoeman
1996tahoeman
No other parts covered in coolant that i know of.
The truck turned off on it's own. I tried starting it back up and it started so i then turned it off right away.
retorq
Kingman AZ
You probably overheated and broke something if it turned off itself ...
HDRock1
Flint,Mi
I had a car over heat and it cracked the dizy cap.
Coil isn't far from that hose.
Like Dylan said Check for spark and fuel
Smokeshow379
