Hello from Arizona - 2013 Tahoe
Tozan
Overlander
Yavapai Arizona
Yea if you are not wanting to get too crazy out there big tires are not very necessary just stay away from washed out roads. I have 35's on mine and changing a 106 pound tire is not an easy task when off road. If you get a lift be sure to get a jack too lift it up too.
I live near Wickenburg and would be up for a camping trip when it starts cooling down.
If you want some ideas on modifications check out my build and feel free to ask questions..
I have a full size sleeping area and behind the front passenger seat is a 12 volt refrigerator. This set up gives you a ton of storage space.
scot_c
scot_c
That's a cool setup. I took out the passenger side rear bucket and 3rd row seats so I have a 6+foot by 24" sleeping space plus the other 24" side for storage. Will send pics when I get home from vacation (not in Tahoe). I wanted to keep seating for 3, or more if I put 3rd row seats back in. I had 265/70 R16s on a Toyota 4 runner and they were fine for what I did. But getting an extra inch of clearance under the differential would be nice with bigger tires.
I'd like to do a camping trip with you. I've never camped near Wickenberg or that part of the state. I hope to get up north in the next few weeks or so, once I get the Tahoe fixed up.
scot_c
scot_c
"Just bought a 2013 Tahoe LT 4WD for off-road car camping."
Some of you wanted me to post pictures, etc. Details are: 2013 Tahoe LT with 125,000 miles, 4WD, 2 speed transfer case, completely stock. Photos attached.
Immediate mods are minimal at this point: Skid plates (used factory), KO2s. Future mods are possibly mild lift (2 to 2.5" so I can keep stock suspension). Problem is I've got the self-leveling (Novimat?) rear shocks and not sure if a simple spacer will work. Would like to add metal front engine splash guard and rear differential protection. Might fabricate fuel tank skid plate.
I've used a 96 Toyota 4Runner and a 2017 Subaru Forester for car camping. Loved the 4Runner but the Subaru didn't have enough head room. Plenty of room all around with the Tahoe.
Photos are stock vehicles, loaded interior (a work in progress) and interior unloaded for sleeping. I always remove the gear on the right to set up camp, so sleeping in the truck is much easier than setting up a tent. If you can't tell, I took out the right 2nd row bucket seat and the 3rd row seat. Their brackets make good tie-down points.
Three of the bins contain rescue/emergency gear. I carry a lot since I usually travel alone.
When I get around to it, I'll post a link to an inventory of what I carry since it'll be too long for a forum post, unless someone has a better idea.
The gear is either tied town or stowed so that one piece supports the other. It would be chaos in an roll over, so I'm still working where and how to stow everything.
Scot_c
Scot_c
Should not have Nivomats from the factory. If your RPO sheet has Z55 and G69, you have AutoRide, rear air shocks with a compressor. Check out the plates used under the pick up trucks, they also have 26 gallon fuel tanks, and see if they might work for you.
scot_c
scot_c
I have the ZW7 suspension, Premium Smooth Ride, that I understood to have the Nivomats.
Thanks for the suggestion on the pickup skid plates.
Not from the factory, Nivomats were used on the 800s and not the 900s. You have the plain and easy to maintain suspension, the rear end should stick up about 3 inches or so more than the front when unloaded. You can more easily choose which lift kits you want.
scot_c
scot_c
I just found a reference list that says 900's with just the ZW7 code have standard shocks and springs but if it also has the G65 code, it has auto-leveling (Nivomat). I don't have the g65 code, so looks like I'm OK to swap out shocks or add spacers.
scot_c
scot_c
Oops. Looks like you posted that chart. Thanks, it made things a lot clearer.
masonstahoe06
