Hellwig vs Hotchkis sway bars and how hard to install
rdhogg
Houston
You won't be disappointed. I just installed mine and they make a HUGE difference. The front bar is HEAVY, so you may need a jack or a second set of hands to lift and hold it in place, until you have secured the 2 U-brackets.
Thanks for the heads up on being heavy. It'll have to be a jack in my case.
rdhogg
Houston
I just noticed that you in stalled a couple of 8" light bars under the rear bumper for additional back up lighting. Could you post some pictures of how you mounted them and where did you tie into the back-up lighting wiring. I have put CREE LED bulbs in but it still does not give the light I want for backing up. Thanks for your help
I was just looking at the installation instructions and it said that if you have a 6 speed tranny that you will need Spacer Kit 7799 to provide clearance for the tran cooling lines. Did you run into that issue Thanks
Hellwig's instructions say that if you have the 6 speed transmission, you need to install the spacers. But, their instructions also apply to GMC/Chevy pickup trucks, as well, so the spacers may be specifically needed for those vehicles. While upon visual inspection, the Hellwig sway bar did not seem to be in danger of contacting the transmission cooling lines (though the truck was not in a position where the middle of the sway bar was at it highest travel apex), I installed the spacers on my truck anyway, just in case, as I did not want to chance having crushed transmission cooling lines.
I had the same issue. I put a good set of LED backup lights in backup light sockets, and while much improved over stock filament light bulbs, it was still not nearly enough for me to easily navigate my driveway in the dark.
Photos:
Light attachment setup:
https://www.tahoeyukonforum.com/thr...backing-up-to-see-better.111002/#post-1329194
Light bar light pattern:
https://www.tahoeyukonforum.com/threads/what-is-this-button-solved.120958/page-9
Russ Giles
Just installed front and rear Hotchkis Sway bars and Moog sway bar links on my 2015 GMC Yukon XL Denali. Bought the complete front and rear kit which did not say in the description but included basic front sway bar links in the box.
Old rear bar was looking aged and sway bar links were showing some rust.
Quality fit and finish with zerk fitting to lube the rubber bushings and rear lower sway link ball joint. Install was straight forward except the supplied bolts were short and used an allen key which does allow for higher torque, so after trial and error I reused the OEM bolts with the supplied washers.
Feels better with less body lean.
Just because a one company says they have a solid bar does not make it stiffer than a hollow bar. Stiffness is a function of the metal blend, and the hardening process. a solid block of cheese is still cheese. If the the hollow bar is hardened and shaped properly it will be stronger and more stiff at less weight.
rdhogg
Houston
Thanks for the review, I had ADDCO bars ordered from SDTruck Springs but the delivery was out in June, canceled it and ordered Hellwig , should be here 4/13, Rear bar has new Links( don't know if they have zerk fittings or not)but needed to order Mevotech TTX replacement links for the front.
dirt
